Старый 18.01.2022, 14:11   #1
crmtipoftheday: Tip #1423: Search for solution that does not exist
Источник: https://crmtipoftheday.com/1423/sear...does-not-exist
You are about to record or present a demo but your environment contains all the demos you performed previously and looks like this (zoomed out for brevity):
What you are about to do next is what I call the “sweeping under the rug”:
Search for the solution that does not exist yet
Thee Nabler
If you are about to create a demo solution Unicorns and Gluten, search for it first then your screen will be clean as a whistle:
And once created, solution will be the only one present. Nice and clean demo ahead.
Congratulations, you just successfully performed the “sweeping under the rug” manoeuvre.
Cover photo by Bob van Aubel on Unsplash
crmtipoftheday: Tip #1402: Why you should not use Microsoft Lists/SharePoint Lists for business-critical Power Apps Blog bot Dynamics CRM: Blogs 0 17.02.2021 15:12
crmtipoftheday: Tip #1270: Table or view is not full-text indexed Blog bot Dynamics CRM: Blogs 0 04.06.2019 14:11
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
Быстродействие метда TaxParameters::find Ace of Database DAX: Программирование 7 01.06.2017 11:46
Часовой пояс GMT +3, время: 23:31.
