Старый 09.09.2014, 23:11   #1
25,491 / 846 (79) +++++++
tlefor: AX2012: Reading a string from an AOT resource
Источник: http://blogs.msdn.com/b/tlefor/archi...-resource.aspx
Sometimes the most basic of concepts become a challenge unless you've seen an example or have any idea that they exist at all. Within Dynamics AX, the use of resources to persist images, blobs or strings is one of those concepts. This is a quick example of how to obtain modeled data that has been persisted as an AOT resource within AX2012.
 static str getResourceString(SysElementName _resName)
    resourceNode resourceNode = SysResource::getResourceNode(_resName);
    container stringContainier;
     if (!resourceNode)
        return '';
     resourceNode.AOTload();
     stringContainier= SysResource::getResourceNodeData(resourceNode);
    return conPeek(stringContainier, 1);
The string can contain default data, XML, HTML or whatever else your application needs.
Последний раз редактировалось mazzy; 10.09.2014 в 08:49.
Axilicious:The given value of type String from the data source cannot be converted to type nvarchar of the specified target column. Blog bot DAX Blogs 0 17.03.2014 18:11
X++: More help needed from community: Do you rely on string truncation? Blog bot DAX Blogs 4 19.03.2010 10:50
palleagermark: Create a 64-bit encoded string from an image in AX Blog bot DAX Blogs 0 22.01.2010 15:05
Kashperuk Ivan: Running a class from AOT or "How to assign a class to an action menu item?" Blog bot DAX Blogs 0 22.10.2009 20:05
axaptapedia: Create New AOT Project From Template Blog bot DAX Blogs 0 29.08.2008 21:10
Часовой пояс GMT +3, время: 14:52.
