#1 |
butenko.pro: Adding a PCF Control to the Dataverse Application Navigation (SiteMap)
Источник: https://butenko.pro/2022/01/31/addin...ation-sitemap/
============== At the moment unfortunately it’s not possible to put PCF directly to the SiteMap but I found a workaround you can use that I described in this post. Entity In order to place PCF Control to the Sitemap, you have to create a “stub” entity that will serve as a placeholder for a PCF Control. ... The post Adding a PCF Control to the Dataverse Application Navigation (SiteMap) appeared first on Andrew Butenko's Blog. Источник: https://butenko.pro/2022/01/31/addin...ation-sitemap/
