Старый 09.11.2020, 16:13   #1
crmtipoftheday: Tip #1387: Power Apps Form submitted but data not saved
Источник: https://crmtipoftheday.com/1387/powe...data-not-saved
The following tip is from Triasha Jalui. (Got a tip? Email it to jar@crmtipoftheday.com)
You create a Power Apps canvas app, add a form, bind it with the Common Data Service entity. On the form you add all the necessary fields. Now you want to save the form/record. You use the SubmitForm function in the OnSelect property of a Button or Icon to save or update the form but some of the fields value is not saved while the record is created or updated.
SubmitForm validates some of the behavior while submitting the record. Sometimes the Update property on the Card for the field is blank. If that happens, the field value is not saved or updated in CDS. Make sure the Update property on the fields Card is set while developing the Canvas App.
crmtipoftheday: Tip #1321: Formatting currency values in Power Apps portals Blog bot Dynamics CRM: Blogs 0 10.02.2020 18:11
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
Быстродействие метда TaxParameters::find Ace of Database DAX: Программирование 7 01.06.2017 11:46
atinkerersnotebook: Using Power BI to Visualize Customer Saturation Blog bot DAX Blogs 1 07.08.2013 08:11
Часовой пояс GMT +3, время: 23:42.
