#1 |
crmtipoftheday: Tip #1386: I miss the green bar
Источник: https://crmtipoftheday.com/1386/i-mi...-the-green-bar
============== If you use the new solution import process at make.powerapps.com, you might miss the old green bar that told you how far the import had proceeded. ![]() Run this query with the XrmToolBox and refresh until the import finishes. Thanks to Ivan Kurtev for the suggestion. Источник: https://crmtipoftheday.com/1386/i-mi...-the-green-bar
