Старый 03.02.2019, 12:11   #1
dynamicsaxinsight: AX 2012: Existing DIXF service for new AOS instance
Источник: https://dynamicsaxinsight.wordpress....-aos-instance/
Product:
Dynamics AX 2012
Purpose:
The purpose of this document is to explain what we can do to reuse a DIXF service of an existing AOS instance for a new AOS instance
Steps:
Copy paste the following files from the bin folder of an existing AOS instance to the bin folder of the new AOS instance:
  • DMFClientConfig.xml
  • DMFConfig.xml
  • Microsoft.Dynamics.AX.Framework.Tools.DMF.ServiceProxy.dll.config
emeadaxsupport: DIXF – AX 2012 R3 – KB3216243 – Assume service is on active SQL Server node Blog bot DAX Blogs 0 04.01.2017 20:13
atinkerersnotebook: New Configuration Blueprint Available: Configuring Service Management To Track Service Orders within Dynamics AX 2012 Blog bot DAX Blogs 0 19.09.2016 00:21
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
DynamicsAxSCM: Service products in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 2 02.06.2011 13:36
Часовой пояс GMT +3, время: 17:12.
