Старый 14.08.2018, 16:11   #1
dynamicsnavax: Using Global Variables with Retail Modern POS
Источник: http://dynamicsnavax.blogspot.com/20...th-retail.html
I am using version 8 platform update 15. Since the POS development is locked out and extensions only is allowed. There are some limitations and a number of objects are not accessible.
I was trying to navigate to the customer search and allow the user to select a customer and return to the calling form. This was very challenging.
One possible solution I found is to use Global variables. I used the window object.
To do this, declare the window object as per screenshot. And then just set your object :
eg. window.MyVarName = WhatEverObject;
To get the value just invert it.
You can see how I have the customer object in debug.
Credit to one of my colleagues who suggested this solution.
kurthatlevik: First Aid Kit for Dynamics 365 for Retail; A messy blog post Blog bot DAX Blogs 0 10.05.2018 17:11
powerobjects: How to Configure a Point of Sale in D365 for Retail in a Day Blog bot Dynamics CRM: Blogs 0 17.03.2018 02:19
emeadaxsupport: AX for Retail: Modern POS Custom Labels and Strings Blog bot DAX Blogs 0 24.05.2017 23:13
axsa: How to connect Modern POS to Dynamics AX 2012 R3 CU8 instance in Azure Blog bot DAX Blogs 0 07.02.2015 12:11
Rahul Sharma: Dynamics AX for Retail POS Development Blog bot DAX Blogs 2 19.09.2011 15:30
Часовой пояс GMT +3, время: 19:10.
