Старый 23.02.2018, 05:24   #1
crmtipoftheday: Tip #1082: Forming an opinion on which form
Источник: https://crmtipoftheday.com/1082/form...on-which-form/
If we use ClickDimensions and Dynamics Portals, we have a wealth of options when it comes to creating a form for an external party to fill out. We have:
  • Dynamics Portals Web Forms (and Entity Forms but these are in my ways a simplified version of Web Forms)
  • ClickDimensions Surveys
  • ClickDimensions Web Forms
The question we may need to ask ourselves is which one to use for a given situation. At this stage I could use an illustrated guide to pave the way. After all, TOTD does occasionally feature flow diagrams. However, I am feeling nostalgic so my tip today will be in the form of a Commodore 64 BASIC program.
1 REM *****DYNAMICS FORMS DECISION TREE*****10 AUTH = AD_AUTHENTICATION_REQUIRED11 CONTACTS_ONLY = ONLY_CAPTURING_INFO_ON_CONTACTS12 SURVEYS = CAPTURING_SURVEYS_ON_EXISTING_CONTACTS13 HTML_FORM = IT_IS_AN_EXISTING_HTML_FORM14 SKIP_QUESTIONS = THE_FORM_SKIP_QUESTIONS_SOMETIMES15 REM *****I DONT DO COLONS*****20 IF AUTH = YES THEN GOTO 100 ELSE GOTO 3030 IF CONTACTS_ONLY = YES THEN GOTO 40 ELSE GOTO 5040 IF COMPLEX_FORM = YES THEN GOTO 60 ELSE GOTO 20050 IF SURVEYS = YES THEN GOTO 70 ELSE GOTO 10060 IF HTML_FORM = YES THEN GOTO 200 ELSE GOTO 10070 IF SKIP_QUESTIONS = YES THEN GOTO 300 ELSE GOTO 100100 LOAD "DYNAMICS PORTAL FORMS", 8200 LOAD "CLICKDIMENSIONS WEB FORMS", 8300 LOAD "CLICKDIMENSIONS SURVEYS", 8
crmtipoftheday: Tip #1045: Missing fields on Dynamics 365 account form Blog bot Dynamics CRM: Blogs 0 18.12.2017 03:33
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 10:36.
