Старый 26.11.2008, 14:12   #1
Session Monitor is not a new tool, but it did stop working with SQL Server 2005. So I think that a lot of people stopped using it, which is a shame. The things that were broken now work again, and I would recommend anyone with any kind of blocking problems to implement this tool. With this post I hope to get some people to use it again, and to provide a new tool to anyone who did not know it exists.
Purpose of the tool
The purpose of the Session Monitor tool is to show a live picture of any current blocks in the Microsoft Dynamics NAV database. And to show it in a familiar environment, i.e. a NAV form. It is an extension of the information you get when going to File -> Database -> Information, and drill down on Sessions.
What the tool does:
  • Shows live information about who is blocked by whom
  • Shows which user is at the top of a blocking chain
  • Shows if a user is involved in blocking, i.e. either being blocked or is blocking someone. So you can filter out all sessions that are not involved in blocking
  • Shows the wait resource, i.e. on which table the block is
This is how the Session Monitor shows a blocking situation:
As default it refreshes every second.
Some of the useful features of Session Monitor are:
  • Filter on "Involved in Blocking". Then, as soon as there is a block it will show up. This is especially useful when you have more sessions that can fit on the screen, which means that there might otherwise be a block outside of the form.
  • Wait Resource tells you on which table the block is, which helps you get some idea about in which area of the application it is.
  • Originating blocker ID shows the head-blocker. This is useful when a user is blocked by someone who is blocked by someone else, etc.
  • Wait Time shows how long the block has been there.
How to get it to work
As mentioned, the tool stopped working in SQL Server 2005. But there are corrections for this now. First, download the tool, which is part of the "Performance Troubleshooting Guide", available for download here (PartnerSource login required):
Часовой пояс GMT +3, время: 03:53.
