Старый 29.08.2014, 02:14   #1
atinkerersnotebook: Importing Sales Order History Through the Data Import/Export Framework
Источник: http://atinkerersnotebook.com/2014/0...ort-framework/
Originally posted on Dynamics AX Tip Of The Day:
When you implement Dynamics AX the last thing that you want to do is keep the old system around just so that you can access the historical information. One example of this is the sales history which is useful for reporting and trending, and also important when a customer calls up and asks about an order from a year ago. You may think that it is too much work to move all of that information over to your new system, but it’s not so. Using the Data Import Export Framework you can bring all of your historical sales orders over and be able to access them from within Dynamics AX.
You’re one step closer to cutting the cord on your old ERP system.
View original 946 more words
emeadaxsupport: Importing a General Journal using Data Import/Export Framework AX 2012 Blog bot DAX Blogs 0 17.07.2014 20:12
atinkerersnotebook: Copy Data Between Companies Quickly Using The Data Import Export Framework Blog bot DAX Blogs 0 16.04.2014 15:11
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7 Blog bot DAX Blogs 0 04.12.2013 04:13
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
Часовой пояс GMT +3, время: 04:44.
