Старый 23.10.2008, 18:05   #1
palleagermark: Finding unused labels
Источник: http://palleagermark.blogspot.com/20...ed-labels.html
Here is a small job for finding labels, from a particular label file, that are not used in the application. You need an updated croess reference before running the job.
static void findUnXedLabels(SysOperationProgress _progress = null)
    Label           label       = new Label('da');  // The language to use for finding the labels
    str 250         labelId     = label.searchFirst('');
    Map             mapLabels   = new Map(types::String, types::String);
    MapEnumerator   mapEnumerator;
    setPrefix("Finding UnX'ed labels");
    while (labelId)
        if (label.moduleId(labelId) == "XYZ") // The particular label file
            if ((select xRefNames
                     index hint Name
                     where  xRefNames.Kind == xRefKind::Label &&
                            xRefNames.Name == labelId &&
                            xRefNames.TypeName == '').RecId == 0)
                mapLabels.insert(labelId, label.extractString(labelId));
        labelId = label.searchNext();
    // The maps is used to sort the lables
    mapEnumerator = mapLabels.getEnumerator();
    while (mapEnumerator.moveNext())
        info (strFmt("%1 %2", mapEnumerator.currentKey(), mapEnumerator.currentValue()));
In standard AX you can run this check for all labelfiles and save the result to a file, by using the \Classes\SysApplCheck\findUnXedLabels method.
За это сообщение автора поблагодарили: kashperuk (5).
palleagermark: Dealing with changed table or field id's Blog bot DAX Blogs 0 11.02.2009 11:05
palleagermark: The book "Dynamics AX: A Guide to Microsoft Axapta" is available on Google Books Blog bot DAX Blogs 0 10.02.2009 15:05
palleagermark: Set focus on a particular field on an EP page Blog bot DAX Blogs 0 27.11.2008 14:05
epblog: Using AX Labels in EP 2009 Blog bot DAX Blogs 0 02.07.2008 00:07
axStart: version control with VSS by using Labels BETA Blog bot DAX Blogs 0 09.01.2008 04:34
Часовой пояс GMT +3, время: 12:38.
