Старый 11.08.2012, 01:27   #1
Danny Varghese: .NET Application Domain
Источник: http://varghesedanny.com/2012/08/10/...cation-domain/
I was recently listening to a recorded presentation about application domains, and wanted to know more about them.  An application domain is way to run code in an isolated region inside a process.  You can find out more information here.
Application domains allows code to run in isolation so that if something happens, it  won’t adversely affect another application. For example, Windows uses processes to run applications.  If something fails, the process stops running, but it may not affect the OS.  Another interesting note the Microsoft documentation provides is that you cannot communicate between the two processes running unless you use proxies.
Another advantage of application domains is security, and the MS documentation gives a great example of “running several web applications in a single browser process in such a way that the controls cannot access each other’s data and resources.”
I thought this is some interesting pieces of information.
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
axnontechnical: How Do I Integrate an Application Using .NET Business Connector Blog bot DAX Blogs 0 04.04.2012 05:16
Danny Varghese: CRM 2011 VM Released Blog bot Dynamics CRM: Blogs 0 07.06.2011 12:11
Danny Varghese: CRM 2011 Installing User/Service Account Permissions Blog bot Dynamics CRM: Blogs 0 18.05.2011 03:15
Danny Varghese: Dynamics CRM 2011 Licensing Blog bot Dynamics CRM: Blogs 0 18.05.2011 03:15
Часовой пояс GMT +3, время: 16:16.
