Старый 29.01.2011, 14:12   #1
daxdilip: Dynamics AX 2009 Integration with PowerShell to unzip files
Источник: http://daxdilip.blogspot.com/2011/01...tion-with.html
Had a requirement to unzip files from AX for one of our interfaces. I didn't want to install any third party software on our server as the security policy prevents it.
Tried using Microsoft.Deployment Framework within AX (http://www.eggheadcafe.com/software/...eployment.aspx), but ran into issues using the framework to unzip files.
Solution
Since, our AOS Servers run on Windows Server 2008 and Powershell is something which comes default with this edition of windows, I thought why not leverage it as it has a powerful scripting engine and I can see it as a predecessor to VB Scripting.
Following code snippet, is the powershell script which I wrote to unzip the files.
And, here is the X++ code which calls the script
I remembered my Unix scripting and vi editor days when working on Powershell editor.
Also, this is a very useful reference if you are graduating from VBScript to Powershell
http://technet.microsoft.com/en-us/l.../ee692947.aspx
Some other useful links on Powershell from Axaptapedia and Brandon's blog
http://www.axaptapedia.com/PowerShell
http://dynamics-ax.blogspot.com/2010...owershell.html
Happy Powershelling with DAx!
Проблема: Массовое развертывание клиентов Dynamics Ax 2009 Poleax DAX: Администрирование 8 23.08.2012 17:28
Часовой пояс GMT +3, время: 01:04.
