Старый 06.08.2010, 17:05   #1
dax-ideas: Displaying the names of the files in the directory
Источник: http://dax-ideas.blogspot.com/2010/0...directory.html
To display names of the files in directory
static void ShowFileNameinDirectory(Args _args)
int handle;
FilePath filePath;
FileName FileName;
filepath = "D:\\Cole Hersee Reports";
[handle,filename] =
WinAPI::findFirstFile(filepath + "\\*.xls");
while (filename)
info(filepath + "\\" + filename);
filename = WinAPI::findNextFile(handle);
WinAPI::findClose(handle);
dax-ideas: Getting the names of all the tables in AX Blog bot DAX Blogs 0 06.08.2010 17:05
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 04.05.2009 14:05
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 08.08.2008 19:06
xInfo::Directory DAX 4.0 Tarrash DAX: Программирование 2 07.04.2007 23:08
Часовой пояс GMT +3, время: 03:33.
