Старый 28.10.2010, 12:05   #1
palleagermark: Using X++ to figure out which user the AOS runs under
Источник: http://palleagermark.blogspot.com/20...-user-aos.html
This code will give you the AOS accounts domain and username:
public static void main(Args args)
    InteropPermission   permission;
    str                 userName;
    str                 userDomain;
    permission = new InteropPermission(InteropKind::ClrInterop);
    permission.assert();
    userDomain  = System.Environment::get_UserDomainName();
    userName    = System.Environment::get_UserName();
    info(strFmt(@"%1\%2", userDomain, userName));
The code must be executed from the server tier.
palleagermark: Parsing a custom parameter from a user control to a data set used on another user control Blog bot DAX Blogs 0 28.10.2010 12:05
daxis: Troubleshooting blocked SPIDS in AOS Blog bot DAX Blogs 0 01.04.2009 18:05
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
Вылетает аxапта 4.0 при завершении работы Delfins DAX: Прочие вопросы 5 27.06.2007 15:43
Часовой пояс GMT +3, время: 02:52.
