Старый 28.09.2007, 14:40   #1
axaptafreak: Clear SQL Cache
Источник: http://axaptafreak.blogspot.com/2007...sql-cache.html
When you do performance tests in Dynamics AX, you often want to clear the SQL cache so you can be sure that all data must be re-read from the disks.
If you want to clear the SQL cache, execute these 3 lines in a query window:
CHECKPOINT
DBCC DROPCLEANBUFFERS WITH NO_INFOMSGS
DBCC FREEPROCCACHE WITH NO_INFOMSGS
Helmut Wimmer
За это сообщение автора поблагодарили: Kabardian (0).
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
Dynamics AX: SQL Sever 2008 - Performance with Dynamics AX 2009 - Resource Governor Blog bot DAX Blogs 0 23.01.2009 22:05
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
Часовой пояс GMT +3, время: 22:02.
