Старый 31.12.2010, 10:16   #1
daxdilip: Contd..How to Add multiple Search Criteria using EWS
Источник: http://daxdilip.blogspot.com/2010/12...le-search.html
This is in continuation with the previous posts on integrating Dynamics AX with Exchange Web Services without installing Outlook on your box. If you missed the previous posts, you can browse them from here:
http://daxdilip.blogspot.com/2010/12...-download.html
http://daxdilip.blogspot.com/2010/12...using-ews.html
Had this requirement to add multiple search criterias for filtering emails based on different subjects. For this, I had to use the SearchFilterCollection method to achieve it, below is the code snippet on how to achieve it. The code is pretty self explanatory as the SearchFilterCollection object can handle logical operators like Or, And etc. and you can pass multiple SearchFilters to it as shown here.
If you want to delve more indepth, you can read the MSDN article below: http://msdn.microsoft.com/en-us/libr...EXCHG.80).aspx
daxdilip: Tip How to Encode URL for Dynamics AX 2009 Enterprise Portal Link Blog bot DAX Blogs 0 15.12.2010 17:11
daxdilip: [Updated] Code to read email using EWS (Exchange Web Services) Blog bot DAX Blogs 0 15.12.2010 17:11
daxdilip: How to Read email and download attachment from AX (AOS) without Installing Outlook Client and using EWS Exchange Web Services Blog bot DAX Blogs 0 11.12.2010 13:11
workflowax: How to run multiple Dyanamics AX workflow websites on IIS 7 Blog bot DAX Blogs 0 10.12.2010 18:11
CRM DE LA CREME! Cannot add users in crm using "Add Multiple Users" Blog bot Dynamics CRM: Blogs 0 01.02.2010 18:06
Часовой пояс GMT +3, время: 23:37.
