#1 |
crmtipoftheday: Tip #1206: View any Dynamics 365 record on a calendar
Источник: https://crmtipoftheday.com/1206/view...on-a-calendar/
============== I want to see a calendar of my opportunities based on estimated close date (or other date field on the opportunity record). Can I do that, or do I need to license a third party add-on?If you use unified interface, you can display any record in a calendar view via the calendar control.
![]() ![]() To switch back to the list of records, click the “…” button on the command bar, and select read only or editable grid (if enabled) to toggle to the normal list view. ![]() The calendar control properties allow you to specify two different date fields–start date and end date. If you have two dates that are sequentially related, such as schedule date and installation date, you can map both of these values, and that will determine the time block duration of the item on the calendar view. If you have multiple unrelated dates or want to have different views displaying different dates, the calendar control is not designed to work that way. Источник: https://crmtipoftheday.com/1206/view...on-a-calendar/
Опции просмотра | |
