Старый 07.03.2024, 11:11   #1
crmtipoftheday: Tip #1448: Never delete columns in translation
Источник: https://crmtipoftheday.com/1448/neve...in-translation
Another day, another guest Q&A post. (Have a tip of your own? Send it to jar@crmtipoftheday.com)
Question
I saw the Easy Translator · XrmToolBox was updated, so thought I would give it another try on our app which is in 14 languages. Tanguy, can i delete rows and tabs that do not require translation? Or will it cause problems?
Steve “The Pot Stirrer” Mordue
Answer
Never delete columns. But you are free to delete rows and tabs
Tanguy “The XRM Toolbox” Touzard
Tîpp Jäår $0.02 + GST
What Tanguy was referring to is Excel file that you get when you export customized table and column text for translation with Power Apps. Tabs contain types of tranlsations required, rows refer to individual strings requiring translations while columns contain languages. So, yes, Steve would have to look at all 14 columns.
The post Tip #1448: Never delete columns in translation appeared first on Power Platform & Dynamics CRM Tip Of The Day.
crmtipoftheday: Tip #1402: Why you should not use Microsoft Lists/SharePoint Lists for business-critical Power Apps Blog bot Dynamics CRM: Blogs 0 17.02.2021 15:12
crmtipoftheday: Tip #1367: Tell apart create, update, and delete events Blog bot Dynamics CRM: Blogs 0 22.06.2020 18:13
crmtipoftheday: Tip #1170: Turn on soft delete in Azure Blob Blog bot Dynamics CRM: Blogs 0 11.09.2018 00:14
crmtipoftheday: Tip #1157: Do not delete system components Blog bot Dynamics CRM: Blogs 0 22.08.2018 14:11
crmtipoftheday: Tip #1089: User Delete Privileges Stretch Further Than You Think Blog bot Dynamics CRM: Blogs 1 20.03.2018 13:24
Часовой пояс GMT +3, время: 16:22.
