Старый 21.01.2022, 19:11   #1
crmtipoftheday: Tip #1425: Dataverse CSV import using alternate keys
Источник: https://crmtipoftheday.com/1425/data...alternate-keys
Today’s tip is from Alex McLachlan (@alex_mcla), saving the day (no kidding – I used it the very next day after receiving the tip). You can be a hero too by emailing your tip to jar@crmtipoftheday.com!
With the classic import experience, you couldn’t use a CSV import containing an Alternative Key column to update existing records. See (2) Update existing records on import (using alternate keys – account number)??? – Microsoft Dynamics CRM Forum Community Forum
Now with Import from Excel > Import from CSV gives:
Selecting the Alternative Key then allows update of existing records in the CSV file. The Alternative Key needs to be included in the Data Mapping.
Tîpp Jäår $0.02 + GST
If you’d like to consume a video, Power CAT team has one just for you:  Easier Imports With Dataverse Alternate Keys – Power CAT Live – YouTube.
Cover image by hudsoncrafted | Pixabay
crmtipoftheday: Tip #1409: Count records for all tables in Dataverse Blog bot Dynamics CRM: Blogs 0 28.08.2021 21:39
crmtipoftheday: Tip #1402: Why you should not use Microsoft Lists/SharePoint Lists for business-critical Power Apps Blog bot Dynamics CRM: Blogs 0 17.02.2021 15:12
crmtipoftheday: Tip #1396: Multi-currency aggregates in Dataverse Blog bot Dynamics CRM: Blogs 0 28.01.2021 17:11
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
crmtipoftheday: Tip #1041: Make Dynamics 365 data import less rigid Blog bot Dynamics CRM: Blogs 0 11.12.2017 03:41
Часовой пояс GMT +3, время: 07:36.
