Старый 23.09.2021, 11:11   #1
crmtipoftheday: Tip #1417: Power Excel in SharePoint
Источник: https://crmtipoftheday.com/1417/powe...-in-sharepoint
You’ve seen us in Tip #1415 doing some Microsoft Graph abracadabra to call Excel functions directly from Power Automate. To do that we use Excel spreadsheet located on OneDrive for Business. Documentation mentions in passing that “You can use Microsoft Graph to allow web and mobile applications to read and modify Excel workbooks stored in OneDrive for Business, SharePoint site or Group drive” but none of the examples uses SharePoint, everyone is obsessed with /me/drive/. Brian asks a fair question:
Is it possible to do with an excel document stored in a SharePoint document library?
Brian
Lo and behold. The syntax is similar except instead of /me/ you have to point to the site, i.e. /sites/root/lists/{list-id}/ (if your list is on the root site). For example this will calculate the average:
POST https://graph.microsoft.com/v1.0/sit...econtent-type: Application/Json authorization: Bearer {access-token} { "values": [1,2,3,4,5]} Cover photo by salvatore ventura from Pexels
crmtipoftheday: Tip #1415: Call Excel functions from Power Automate Blog bot Dynamics CRM: Blogs 0 20.09.2021 16:12
crminthefield: Dynamics 365 and Power Platform Monthly Update-September 2021 Blog bot Dynamics CRM: Blogs 0 11.09.2021 09:04
crminthefield: Dynamics 365 and Power Platform Monthly Update-August 2021 Blog bot Dynamics CRM: Blogs 0 12.08.2021 06:20
crminthefield: Dynamics 365 and Power Platform Monthly Update-July 2021 Blog bot Dynamics CRM: Blogs 0 14.07.2021 02:22
crmtipoftheday: Tip #1402: Why you should not use Microsoft Lists/SharePoint Lists for business-critical Power Apps Blog bot Dynamics CRM: Blogs 0 17.02.2021 15:12
Часовой пояс GMT +3, время: 15:03.
