Старый 18.08.2021, 11:11   #1
d365technext: Export All Legal entities data using One project in D365FO
Источник: http://d365technext.blogspot.com/202...ata-using.html
Export all legal entities data
In D365FO, if an export project is created for an entity, it exports the data only from the legal entity for which the user has triggered an export.
Setting the property ‘Enable cross-company in the base query of the entity will not help you here.
The behaviour is decided by one of the properties in the Data Entity.
You need to check the value of ‘Primary company context‘ in the entity. By default, it is set to ‘DataAreaId’. This means the data will be exported specifically to the company.
Clear the value from this property if the requirement is to export data from all the legal entities in a single execution.
sertandev: How to integrate with Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 21.08.2020 15:12
d365technext: Export & Import Project D365FO Blog bot DAX Blogs 0 16.08.2018 14:11
atinkerersnotebook: Configuring a BYODB and Creating a Full and Incremental Entity Export Blog bot DAX Blogs 0 25.05.2018 15:11
dennis365foroperations: Yes, it’s here! The Copy configurations feature (and a look at other improvements related to Data Management) Blog bot DAX Blogs 0 12.10.2017 16:11
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Часовой пояс GMT +3, время: 07:53.
