Старый 28.04.2020, 14:11   #1
crmtipoftheday: Tip #1345: When Power Automate picks the wrong type
Источник: https://crmtipoftheday.com/1345/when...the-wrong-type
When using the Parse JSON action in Power Automate, flow will guess what type of data your fields are. Sometimes it guesses incorrectly, such as thinking a number field should be a text string.
When this happens, you will only be able to select the field for test fields, not number fields in update record steps.
To fix this, simply delete the “type” line from the JSON schema. Then the field will be available to be selected for all field types.
crmtipoftheday: Tip #1336: Find your plan in Power Platform Blog bot Dynamics CRM: Blogs 0 24.03.2020 08:11
crmtipoftheday: Tip #1322: Incorrect increment and decrement in Power Automate Blog bot Dynamics CRM: Blogs 0 11.02.2020 15:11
crmtipoftheday: Tip #1317: Make lead qualification better with Power Automate Blog bot Dynamics CRM: Blogs 0 17.12.2019 02:30
crmtipoftheday: Tip #1096: Apply Power BI theme to regular charts Blog bot Dynamics CRM: Blogs 0 03.04.2018 05:35
Часовой пояс GMT +3, время: 08:18.
