Старый 16.08.2018, 07:12   #1
dynamicsaxse: August 2018 – Update on ACS retirement and Dynamics 2012
Источник: https://blogs.technet.microsoft.com/...dynamics-2012/
The work for providing updated solutions to work without ACS is ongoing, and the team will have a solution prior to the Nov 7 deadline.
For those using Enterprise Portal, you can find the required KB available today. See KB 4133646
For those using WorkflowApprovals, this work is nearing completion. Monitor this blog post and an update will be provide soon with an update. An updated Mobile connector will need to be installed, and new configuration will need to be done to create a new service bus and configure SAS.
For those using Timesheet or Expense mobile, there will be updates across the mobile connector, Azure configuration, and apps that are required. This work is still ongoing and we’ll have a dedicated post and updated documentation to help with setup of the new solution prior to the Nov 7 date.
dynamicsaxse: November 2017 Release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 08.12.2017 10:51
dynamicsaxse: May-June 2017 release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 21.06.2017 00:12
mfp: AX 2012 R2 CU7 has been released! Blog bot DAX Blogs 14 26.11.2013 12:12
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics Mobility and HTML5 ~ the future of Web Apps Blog bot Dynamics CRM: Blogs 0 11.08.2011 23:12
Jim Wang: Dynamics Mobility and HTML5 Blog bot Dynamics CRM: Blogs 0 03.08.2011 09:11
Часовой пояс GMT +3, время: 22:52.
