Старый 10.08.2018, 19:11   #1
crmtipoftheday: Tip #1149: Create custom schedule for your flows
Источник: https://crmtipoftheday.com/1149/crea...or-your-flows/
Today’s tip is from Marius “flow like a river” Lind. (And you can also become a tipster by sending your tip to jar@crmtipoftheday.com)
A great man once asked,
can I set a custom schedule for when to run my flows?
The answer is yes, and like so many other solutions it involves nesting flows.
  1. First, create a flow which has a timer trigger, I created one which triggers once per month.
  2. Next, I create parallel branches inside this flow, for each branch you initialize a new variable.
  3. Now add a “do until” loop which says loop until variable equals whatever you need.
  4. Next you add a/multiple start flow action(s) which triggers the flow(s) in question.
  5. Add a delay action which delays for the time period you need.
  6. Finally add a variable incrementor.
Now you’ve got a flow scheduler which can start your flows in whatever fashion you need. Happy pillaging!
crmtipoftheday: Tip #1148: Use visual controls + calculated fields to create an in-form dashboard Blog bot Dynamics CRM: Blogs 0 08.08.2018 14:11
atinkerersnotebook: Configuring a BYODB and Creating a Full and Incremental Entity Export Blog bot DAX Blogs 0 25.05.2018 15:11
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
crmtipoftheday: Tip #1018: Automatically create Dynamics 365 records from Social Engagement Blog bot Dynamics CRM: Blogs 0 08.11.2017 18:11
Часовой пояс GMT +3, время: 01:45.
