Старый 11.07.2018, 16:11   #1
25,497 / 847 (79) +++++++
crmtipoftheday: Tip #1131: Add some vector finesse to your Unified Interface App
Источник: https://crmtipoftheday.com/1131/add-...interface-app/
We want our users to have confidence in the apps that we create and shove down their deploy. That’s not an easy task according to Steve “Mr SMB” Mordue who asks “How do we display our icon here, instead of puzzle piece in custom app? Puzzle Pieces do not instil confidence.”
“That looks like a vector graphic” – you say and you’d be absolutely right. While there are articles explaining how to add vector images to your entities, they stop short explaining how to add those vectors to the element on the SiteMap. The answer to that question is buried deep down in the documentation for the SiteMap Type schema. It’s not even on the page, you’d have to download Schemas, extract the content, and open Schemas\9.0.0.2090\SiteMapType.xsd. There you’ll find that Area element also has a VectorIcon attribute.
Unfortunately, neither built-in SiteMap editor nor even mighty XrmToolBox addin understand this attribute, so a bit of manual intervention is required:
  1. Upload your vector graphic as a web resource, publish, and make note of the url which is something like /WebResources/foo_/images/bar.svg
  2. Open your sitemap in XrmToolBox SiteMap editor
  3. Save SiteMap to the disk
  4. Edit saved file in your favorite notepad and add VectorIcon attribute to element so that it looks like
  5. Open SiteMap in XrmToolBox to load your changes
  6. Update SiteMap to push it to the server
Note: built-in editor strips away the VectorIcon attribute from the Area element so do the above editing as a very last step and do not use the built-in editor afterwards.
If you don’t have a vector image handy, you can quickly convert whatever you have into svg format. However, that approach won’t give you a scalable image as you’d end up with an embedded bitmap. Unless your app is about Minecraft, you’d be better off creating a true vector image, and you can do just that  using InkScape that has fantastic conversion and tracing capabilities.
Facebook and Twitter cover photo by Niketh Vellanki on Unsplash
crmtipoftheday: Tip #1101: Add a scale break to charts Blog bot Dynamics CRM: Blogs 0 07.04.2018 04:03
crmtipoftheday: Tip #1099: Add Annotations to Charts Blog bot Dynamics CRM: Blogs 0 06.04.2018 06:15
crmtipoftheday: Tip #1095: Add percentage labels to pie charts Blog bot Dynamics CRM: Blogs 0 02.04.2018 04:16
survivingcrm: What’s An “App” in Dynamics 365 Anyway? Blog bot Dynamics CRM: Blogs 0 06.01.2018 22:14
crmtipoftheday: Tip #1024: Make an entity regarding available from Outlook App Blog bot Dynamics CRM: Blogs 0 16.11.2017 20:11
Часовой пояс GMT +3, время: 02:59.
