Старый 30.10.2017, 03:36   #1
sinedax: The client id must be unique across all clients - Dynamics 365 for Finance & Operations On Premises Installation
Источник: http://sinedax.blogspot.com/2017/10/...cross-all.html
Hi Guys
To the same Customer I'm going to install the second On Premise Environment.
During the "Step 18 - Configure AD FS" I had run the following command in order to create the new Application:
.\Publish-ADFSApplicationGroup.ps1 -HostUrl 'https://ax.d365foENVNAME.onprem.contoso.com' -ApplicationName 'Microsoft Dynamics 365 for Operations On-premises ENVNAME'
Here I raised the error "The client id must be unique across all clients"
I checked the log wrote in the same folder as the script and I notice that the process failed to the script "D365FO-OP\D365FO-OP-ADFSApplicationGroup.psm1” at line 199
Here the "workflowClientId" is set with a fixed ID value.
I guess is a error so, I changed the line in:
"$workflowClientId = ([guid]::NewGuid())"
Before rerun the script, delete the partial Application created before through the ADFS Management Console
Till Soon!
NAV Team: Upgrading from Microsoft Dynamics NAV 2009 R2 or Microsoft Dynamics NAV 2009 SP1 to Microsoft Dynamics NAV 2015 Blog bot Dynamics CRM: Blogs 0 23.02.2015 13:00
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 12 Blog bot Dynamics CRM: Blogs 0 30.01.2013 01:11
Часовой пояс GMT +3, время: 16:42.
