Старый 06.03.2017, 17:12   #1
gustafwesterlund: Strange error when deleting managed Solution
Источник: http://gustafwesterlund.blogspot.com...g-managed.html
Seems like that Dynamics 365/CRM doesn't catch all dependencies for managed solutions. This is how you can find and remove one of the tricky ones I got when uninstalling a managed solution which was:
Unhandled Exception: System.ServiceModel.FaultException`1[[Microsoft.Xrm.Sdk.OrganizationServiceFault, Microsoft.Xrm.Sdk, Version=8.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35]]: During Solution Uninstall of Solution Id [solution-guid], cannot find any instances of the component with Component Id c97cd9d7-a0fa-4ed5-b360-3c2ad998a620 and Component Type 2.Detail:
-2147220970
2017-03-06T13:06:54.6280227Z
After some thinking I figured that this was probably a reference to an attribute (Component type = 2) with the Guid = c97cd9d7-a0fa-4ed5-b360-3c2ad998a620 so I opened another attribute and then cut-n-pasted the url. And it seemed that you didn't have to worry about the entity guid:
https://..dynamics.com/tools/systemc...a5efbc05d84%7d
Change to your org, and to the crm-subdomain you are using, which for EMEA is crm4.
You will then see the field editor, and can then show the dependencies of the field and remove all of them manually to make sure they are not bothering the Solution uninstall. After that "publish all" and retry removing the solution.
Gustaf Westerlund
MVP, Founder and CTO at CRM-konsulterna AB
www.crmkonsulterna.se
gustafwesterlund: Finding URL to dependencies on installed managed solutions Blog bot Dynamics CRM: Blogs 0 06.02.2017 22:12
A managed solution cannot overwrite the ReportCategory betlejuice Dynamics CRM: Администрирование 0 05.09.2014 14:42
gustafwesterlund: Managed or unmanaged solutions - and how to remove attributes from managed solutions Blog bot Dynamics CRM: Blogs 0 05.06.2012 18:12
Microsoft Dynamics CRM Team Blog: Internal storage of SiteMap and Form customization in managed solution packages Blog bot Dynamics CRM: Blogs 0 16.11.2010 01:12
gustafwesterlund: Webservice loading strange workflows Blog bot Dynamics CRM: Blogs 0 15.06.2010 00:05
Часовой пояс GMT +3, время: 19:54.
