Старый 11.06.2015, 08:12   #1
Dynamics AX Sustained Engineering: Announcing Cumulative Update 9 for Microsoft Dynamics AX 2012 R3
Источник: http://blogs.technet.com/b/dynamicsa...x-2012-r3.aspx
Microsoft Dynamics AX 2012 R3 CU9 is now available to our customers for download on Lifecycle Services, CustomerSource and PartnerSource. Cumulative Update 9 build number is 6.3.2000.326. For installation instructions, download the Installation guide for cumulative update 9 for Microsoft Dynamics AX 2012 R3.
The newest changes can be found in the What's new in Microsoft Dynamics AX 2012 document found here.
For detailed information on Microsoft Dynamics Ax 2012 R3 CU9 release, please refer to the release notes official KB document KB3063879.
Please note, as happened for AX 2012 R3 CU8, the application version will show a different number of: 6.3.2000.323 if you apply CU9 to an existing install of Ax2012 R3. This is due to all the granular models that are applied to your system through the CU9 install. The one model indicating all models for CU9 has been applied has version number 6.3.2000.323. Using a slipstream process as detailed in the Installation guide will result in the single full model applied for CU9 with build number 6.3.2000.326.
To learn about known issues in cumulative update 9, log into LCS by using CustomerSource or PartnerSource account. Then, in the Issue search box, enter "CU9 known issue" as the query for Microsoft Dynamics AX 2012 R3.
Dynamics AX Sustained Engineering: Announcing an update to enable the use of SQL Server 2014 with the AX 2012 R2 CU7 version of the Data Import/Export Framework (DIXF) Blog bot DAX Blogs 0 23.03.2015 22:12
Dynamics AX Sustained Engineering: Announcing Cumulative Update 7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 15.12.2013 02:18
mfp: AX 2012 R2 CU7 has been released! Blog bot DAX Blogs 14 26.11.2013 12:12
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of App-V 5.0 and TFS 2012 with Dynamics AX 2012 CU5 and Dynamics AX 2012 R2 CU1 Blog bot DAX Blogs 0 01.06.2013 04:38
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 13 Blog bot Dynamics CRM: Blogs 0 27.03.2013 22:12
Часовой пояс GMT +3, время: 19:50.
