Старый 21.02.2015, 17:12   #1
DeniZone: Importing an Excel spread sheet with multiple columns
Источник: http://denizone.blogspot.com/2015/02...heet-with.html
You may have seen it before, but here’s our take:
Case: The end-user has a spreadsheet they want to import, and creating a csv-file is not an option.
Challenge: In Excel the end user needs to set a “ ’ ” in front of the numbers if they are to behave as strings e.g. an account no “123435”. When read in AX the value will be read as 123.435,0000 since is interpreted as a real. To overcome this, the end user must set the ‘ in front of the string e.g. ‘123435. Since there may be several hundred or thousands of records, it is not an option for the end user.
How to import from Excel and format the cells’ content when assigning to variables in AX.
Suggested solution below:
So, you create a dialog etc. for the file import and in the actual method you read the sheet, the code looks like this:
private void readExcelFile()
SysExcelApplication application;
SysExcelWorkbooks workbooks;
SysExcelWorkbook workbook;
SysExcelWorksheets worksheets;
SysExcelWorksheet worksheet;
SysExcelCells cells;
COMVariantType type;
COMVariant variant;
int row=1,errors = 0;
smmBusRelTable smmBusRelTable;
smmBusRelAccount smmBusRelAccount;
XXX_SortingId sortingId;
container errorCon;
application = SysExcelApplication::construct();
workbooks = application.workbooks();
ttsBegin;
try
workbooks.open(filenameopen);
catch(Exception::Error)
throwerror("@SYS19358.");
workbook = workbooks.item(1);
worksheets = workbook.worksheets();
worksheet = worksheets.itemFromNum(1);
cells = worksheet.cells();
type = cells.item(row+1,1).value().variantType();
while(type != COMVariantType::VT_EMPTY)
row++;
// find variant of cell
variant = cells.item(row, 1).value();
// set variant type to smmBusRelAccount
smmBusRelAccount = this.variant2str(variant);
if(smmBusRelAccount)
smmBusRelTable = smmBusRelTable::find(smmBusRelAccount,true);
// if there is a prospect proceed
if(smmBusRelTable.RecId)
variant = cells.item(row, 3).value();
sortingId = this.variant2str(variant);
if(!sortingId)
sortingId = cells.item(row, 3).value().toString();
if(XXX_Table::exist(sortingId,8))
smmBusRelTable.XXX_Field = sortingId;
smmBusRelTable.update();
else
errorCon = conIns(errorCon,maxInt(),strFmt("Error with sorting %1",row,sortingId));
// write to error log
else
errorcon = conIns(errorCon,maxInt(),strFmt("Error with prospect %1",row));
type = cells.item(row+1, 1).value().variantType();
application.quit();
ttsCommit;
info('Import done');
// Header was counted as successful import. 1 is substracted from row to reflect that headers should not count
info(strFmt('Number of items imported %1',(row-1)-conLen(errorCon)));
setprefix(strfmt('@SYS344649',conLen(errorCon)));
while(errors < conLen(errorCon))
errors++;
info(conPeek(errorCon,errors));
In the
while (type != COMVariantType::VT_EMPTY)
we check if there is something the cell read.
Then you assign the variant of the cell
which you then cast to string:
private str variant2str(COMVariant _variant)
str valueStr;
switch(_variant.variantType())
caseCOMVariantType::VT_EMPTY :
valueStr = '';
break;
caseCOMVariantType::VT_BSTR :
valueStr = _variant.bStr();
break;
caseCOMVariantType::VT_R4 :
caseCOMVariantType::VT_R8 :
if(_variant.double())
valueStr = num2Str0(_variant.double(),0);
break;
default :
throw error(strfmt("@SYS26908",
_variant.variantType()));
return valueStr;
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Excel to Import Products & Services in Dynamics AX Blog bot DAX Blogs 0 19.07.2013 15:11
Leon's CRM Musings: Importing Appointments with Multiple Attendees Blog bot Dynamics CRM: Blogs 0 13.07.2013 17:11
emeadaxsupport: Importing a Budget via the Excel Add-in Blog bot DAX Blogs 0 10.09.2012 23:15
daxmusings: Importing Data to AX 2012 Using Excel Add-ins Blog bot DAX Blogs 0 19.01.2012 06:16
Часовой пояс GMT +3, время: 10:05.
