Старый 16.01.2017, 19:11   #1
axinthefield: Why you should be using Team Foundation Server for Dynamics AX lifecycle management?
Источник: https://blogs.msdn.microsoft.com/axi...le-management/
If you already use Team Foundation Server in your Dynamics AX projects, providing all benefits it can give to your teams, or if you are already convinced to use it soon, then this article is not for you. You may not be convinced or, even worst, you may disagree about it to be beneficial to...
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
emeadaxsupport: Renaming an AOT object in Dynamics AX 2009 that is under source control with Team Foundation Server Blog bot DAX Blogs 0 06.10.2009 02:05
Часовой пояс GMT +3, время: 22:02.
