Старый 27.01.2011, 00:13   #1
SysDictCoder: Deleting items from a list
Источник: http://feedproxy.google.com/~r/sysdi...3/BPI8S7tsN58/
Just a quick one to point out a common pitfall when working with list objects. To remove objects from a list you need to use an iterator.
In X++ iterators require the developer to write a loop with calls to more() and next() to check if there are any elements left and make iterator advance to the next element.
Not so when you’re going to delete elements from the list. A call to delete() also advances to the next available element. It makes sense, but if you forget it could make you scratch your head for a few minutes.
So don’t write what I first wrote:
    list = new List(Types::String);
    list.addEnd('a'); list.addEnd('b'); list.addEnd('c'); list.addEnd('d');
    iter = new ListIterator(list);
    while (iter.more())
        value = iter.value();
        if (true) // do a real check
            iter.delete();
        iter.next();
    info(list.toString());
But rather do this:
    while (iter.more())
        if (true) // check value
            iter.delete();
        else
            iter.next();
Either do a delete() or a next(). Not both. The same goes for maps and sets.
And by the way, if you want to do anything other than delete elements it’s highly recommended you use enumerators instead of iterators. The reason is explained here on MSDN.
Microsoft Dynamics CRM Team Blog: Marketing with Dynamic List Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
Microsoft Dynamics CRM Team Blog: List Web Part for Microsoft Dynamics CRM 4.0: Understanding Connections Blog bot Dynamics CRM: Blogs 0 20.01.2009 02:07
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Часовой пояс GMT +3, время: 02:50.
