Старый 23.09.2010, 19:05   #1
emeadaxsupport: Enterprise Portal Web Parts show "Unable to render content" error
Источник: http://blogs.msdn.com/b/emeadaxsuppo...uot-error.aspx
A few weeks ago we were facing the situation that in a new deployed Enterprise Portal site most of the existing Enterprise Portal Web Parts where showing the following error message instead of their supposed content:
Unable to render content due to an error. Please contact your system administrator.
Also the Titel Web Part was affected by this issue. At the end it turned out that some modification done in the past in the Global::webSessionClient methods were the root cause of this issue. After removing all customizations in this method and performing an IISRESET the Web Parts started to work.
If you run ever into this or a similar issue check if you have any modifications in one of the following methods:
  • Global::webSession
  • Global::webSessionClient
  • Global::webSessionClientRemove
--author: Egil Ivar Skjold --editor: Alexander Lachner --date: 23-09-2010
emeadaxsupport: Dynamics AX 2009 Enterprise Portal Web Controls are stored in USR instead of VAR Layer Blog bot DAX Blogs 0 21.09.2010 13:05
daxdilip: Troubleshooting AX 2009 Enterprise Portal Error The type or namespace name "Portal" does not exist in namespace 'Microsoft.Dynamics' Blog bot DAX Blogs 0 12.08.2010 11:05
emeadaxsupport: Error "Unable to render content due to an error" when editing Timesheet Blog bot DAX Blogs 0 06.08.2010 17:05
emeadaxsupport: HTTP 401 Error when trying to deploy/create an Enterprise Portal site on a load balanced farm using a hardware load balancer Blog bot DAX Blogs 0 06.05.2010 03:16
Часовой пояс GMT +3, время: 00:02.
