Старый 17.06.2010, 02:08   #1
Dynamics AX Sustained Engineering: Form 27A printing issues when printing to .pdf file format
Источник: http://blogs.technet.com/b/dynamicsa...le-format.aspx
This post describes solutions to issues with Form 27A when printed to .pdf file format.
1. First problem : Lines in PDF printout are overlapping
Solution: Here in PDF Text is bounded by lines to make Text Boxes. To resolve this issue change the property (LineRight #Solid) of Text written in Left
(Eg. Text:Name_2) to (LineRight #None) and for the Text written in Right(Eg. Text:Name_2_1), change the property (LineLeft #Solid) to (LineLeft #None).Put one new control as Shape in Design of Report of having height of total text box length.Example of Properties for the Text Box:Left #50.00mmTop #54.00mmWidth #AutoHeight #48.00mm2. Second Issue : PDF left margin is not lined up properly.Solution: To resolve this issue change the values of Text property(LeftMargin) to align the report. Text:Name of Permises_2 Left Margin property should be set to 1.00mm.3. Third Issue : Text does not fit in the area of Text Box.Solution: To resolve this issue change the value of Text properties(Left, Width, FontSize).Example of Properties of the text:Left 56.00mmWidth 47.50charFontSize 74. Fourth Issue : Text is overlapping in the Control Totals section.
Solution: To resolve this issue change the value of Text property(Left, Width) and for Text(Alignment).
Examples:
Text:Amount_4_3
Left 64.00mm
Width 30.00char
Text:NoOfDeductee_4_2
Alignment Left
Dynamics AX Sustained Engineering: Performance issue in "Open Transaction Edit" form Blog bot DAX Blogs 0 26.10.2009 20:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching Blog bot DAX Blogs 0 08.10.2008 10:05
Часовой пояс GMT +3, время: 17:44.
