Старый 04.05.2007, 18:54   #1
art06 is offline
art06
Аватар для art06
192 / 10 (1) +
Добрый день.
Ситуация следующая - пользователи постоянно подвисают. /Такого раньше небыло. практически не возможно работать.
Может кто-то что-то подскажет по логам -
2007-05-04 15:38:44.14 server Microsoft SQL Server 2000 - 8.00.194 (Intel X86)
Aug 6 2000 00:57:48
Copyright © 1988-2000 Microsoft Corporation
Standard Edition on Windows NT 5.2 (Build 3790: )
2007-05-04 15:38:44.14 server Copyright © 1988-2000 Microsoft Corporation.
2007-05-04 15:38:44.14 server All rights reserved.
2007-05-04 15:38:44.14 server Server Process ID is 392.
2007-05-04 15:38:44.14 server Logging SQL Server messages in file 'C:\Program Files\Microsoft SQL Server\MSSQL\log\ERRORLOG'.
2007-05-04 15:38:44.15 server SQL Server is starting at priority class 'high'(4 CPUs detected).
2007-05-04 15:38:45.25 server Working Set size set to 1651840 kilobytes.
2007-05-04 15:38:45.25 server SQL Server configured for thread mode processing.
2007-05-04 15:38:45.26 server Using dynamic lock allocation. [2500] Lock Blocks, [5000] Lock Owner Blocks.
2007-05-04 15:38:45.32 server Attempting to initialize Distributed Transaction Coordinator.
2007-05-04 15:39:03.62 spid3 Starting up database 'master'.
2007-05-04 15:39:05.50 spid3 0 transactions rolled back in database 'master' (1).
2007-05-04 15:39:05.50 spid3 Recovery is checkpointing database 'master' (1)
2007-05-04 15:39:08.51 server Using 'SSNETLIB.DLL' version '8.0.194'.
2007-05-04 15:39:08.51 spid5 Starting up database 'model'.
2007-05-04 15:39:09.01 spid3 Server name is 'NTS'.
2007-05-04 15:39:09.01 spid8 Starting up database 'msdb'.
2007-05-04 15:39:09.01 spid9 Starting up database 'pubs'.
2007-05-04 15:39:09.01 spid10 Starting up database 'Northwind'.
2007-05-04 15:39:09.01 spid11 Starting up database 'NavisionDataBaseSD'.
2007-05-04 15:39:09.01 spid13 Starting up database 'NavisionLogBaseSD'.
2007-05-04 15:39:09.01 spid12 Starting up database 'NAV'.
2007-05-04 15:39:09.01 server SQL server listening on Shared Memory, Named Pipes.
2007-05-04 15:39:09.01 server SQL Server is ready for client connections
2007-05-04 15:39:09.64 spid12 Analysis of database 'NAV' (8) is 100% complete (approximately 0 more seconds)
2007-05-04 15:39:11.82 spid5 Clearing tempdb database.
2007-05-04 15:39:14.35 spid1 Warning: unable to allocate 'min server memory' of 2048MB.
2007-05-04 15:39:14.89 spid8 Recovery is checkpointing database 'msdb' (4)
2007-05-04 15:39:15.67 spid5 Starting up database 'tempdb'.
2007-05-04 15:39:15.76 spid3 Recovery complete.
2007-05-04 15:39:16.23 spid51 Using 'xpsqlbot.dll' version '2000.80.194' to execute extended stored procedure 'xp_qv'.
2007-05-04 16:00:01.54 spid67 Using 'xpstar.dll' version '2000.80.194' to execute extended stored procedure 'xp_sqlmaint'.
2007-05-04 16:10:07.66 spid68 Error: 9002, Severity: 17, State: 2
2007-05-04 16:10:07.66 spid68 The log file for database 'tempdb' is full. Back up the transaction log for the database to free up some log space..
2007-05-04 16:10:57.64 spid70 Using 'xplog70.dll' version '2000.80.194' to execute extended stored procedure 'xp_msver'.
Я так понимаю что проблема с tempdb. Но, вот что можно сделать чтобы восстановить нормальную работу сервера ?
Старый 04.05.2007, 19:15   #2
Dzemon is offline
Dzemon
1,247 / 12 (3) ++
1. 2007-05-04 15:39:14.35 spid1 Warning: unable to allocate 'min server memory' of 2048MB. устраните эту проблему с памятью.
2. Сходите сюда:
http://www.sql.ru/articles/mssql/01062802S...LServer2K.shtml
Старый 04.05.2007, 19:17   #3
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1849 (69) ++++++++
Сообщение от art Посмотреть сообщение
Первое - у Вас сиквел не патчен вообще. Ни разу
Отключили autogrow для лога Tempdb ? Зачем?
-ТСЯ или -ТЬСЯ ?
Старый 04.05.2007, 19:20   #4
art06 is offline
art06
Аватар для art06
192 / 10 (1) +
по первому - обновляю.
по второму - я к сожелению не зпонимаю о чем идет речь. Подскажите пожалуйста, что такое autogrow, и как его влючить
Старый 04.05.2007, 20:57   #5
Sitizen is offline
Sitizen
Аватар для Sitizen
305 / 10 (1) +
Свойства tempdb, закладка Transaction Log, галочка Automatically grow file.
В смысле, галочка эта отключена, поэтому файл лога не растет автоматически и достиг своего предела.
Старый 04.05.2007, 21:50   #6
art06 is offline
art06
Аватар для art06
192 / 10 (1) +
про эту галочку я знал. просто не сразу полнял. Галочка стоит - процент 10%. Поставил больше. Правда не знаю поможет ли это.
Старый 07.05.2007, 08:42   #7
Vadik is offline
Vadik
Аватар для Vadik
Как у Вас сейчас задан размер tempdb? Подозреваю, что по умолчанию. При таком раскладе бывало - проскакивала ошибка. По ощущениям - когда под создание временного объекта (например, сортировка по массивной выборке) размер БД должен увеличиться, а размер этого инкремента слишком мал (2Мб * 10% = 0.2Мб) и места под объект не хватает. Увеличьте размер tempdb, с которым стартует сервер
-ТСЯ или -ТЬСЯ ?
Старый 07.05.2007, 12:23   #8
art06 is offline
art06
Аватар для art06
192 / 10 (1) +
Было действительно 10 %. Но, я еще в пятницу поставил 100%. Результат работы пользователей не изменился. Выяснил - что запись и считывание данных из хранилищя на котором находиться база - происходит очень медленно. перенес базу на сам сервер - работа пользователей наладилась.
Спасибо за помощь.
Старый 07.05.2007, 12:50   #9
Vadik is offline
Vadik
Аватар для Vadik
вообще-то я спрашивал о начальном размере tempdb, ну да ладно
-ТСЯ или -ТЬСЯ ?
Часовой пояс GMT +3, время: 00:44.
